FS:944 N/a Engine with all maintence done.
Engine is currently still in my Daily Driver, removing for an upgrade. Engine has 102,000 Miles, starts, idles and runs great.
Engine is out of a 85.5 but because DME and AFM are included it can be put into an early car.
It comes complete with the following additional items:
Complete engine
DME & Engine harness
AFM & Airbox
Bellhousing, Clutch Assembly, and Slave cyl. (Slave is only 6 months old OEM Porsche Part
Coil, Cap & Rotor and plug wires
A/C Delete Bracket
Engine has had recent maintence which includes:
Timing and Balence shaft Belt
Waterpump
Front engine reseal
Vacuum lines under intake replaced ( about 3/4 of them, with Porsche parts)
New injectors
Looking to move it as i need the money for the new engine parts...
Have it on EBAY for $650 BIN but will sell it here for $550.
Thanks,
Mark
Complete engine
AFM & Airbox
A/C Delete Bracket
Waterpump
Front engine reseal
New injectors
Thanks,
Mark
Honestly right now i need to sell it complete. If it comes to me parting it ill let you know. I have spent $500 in the last 6 months on this engine, It should be a deal for somone complete.
Mark
Mark
Yeah, I have the LS sitting here, c5 adapter here, motor mounts, engine harness, PCM, throttle body, oil pan and bellhousing all on the way. Only thing stopping me from starting to fit the new engine is this old one in my way. Back to aligning the white devil...
Mark
Mark
Thanks, Ill check out 44cup.com
I plan on going with a Turbo trans with the N/A 5th gear. And for the inital build i will probably end up with a slightly used LS7 Pressure plate and flywheel with a early mopar clutch disk.
Mark
Mark
