OT: Anyone with MATLAB programming knowhow
I have no clue on how to use MATLAB. Never heard of it until I came to WVU.
Anyhow, I want to generate random numbers between the values 27 and 39 for 10000 trails.
when typing in rand(1,10000) you get a result of 10000 numbers that range between 0 and 1 and as stated above i need them for values between 27 and 39.
If ANYONE know how to do this and is willing to share their knowledge, by all means contact me...
email is travis.kirby@us.army.mil if you want to email me
thanks,
Travis
thanks,
Travis
Well, this is sort of backasswards, and I've never used Matlab and may not understand your question, but this may work. I assume you are not dealing with integers.
Simply multiply your result by (39-27) and then add 27.
Example
random number is 0.5423
(0.5423 * (39-27)) + 27 = 33.5076
Example
Yikes!! MATLab and the horror of differential equations and arrays!!! I had pretty much wiped that stuff from my memory. You can check out their website at:
<a href="http://www.mathworks.com/access/helpdesk/help/techdoc/matlab.shtml" target="_blank">MATLab</a>
Under the functions-alphabetical it explains how to use the rand function.
From example 2 with your values:
a = 27; b = 39; 10000 => 100x100 array
x = a + (b-a) * rand(100)
x= your answer.
Ow..my brain hurts, I am going to sleep...
HTH
x= your answer.
HTH
Matlab is fun! You can create strange sounds with it and annoy your friends living next door
» fs=44100;
» t=(0
1/fs):10);
» s=sin(2*pi*50*t);
» soundsc(s,fs)
will give you 10 s of 50 Hz sound in your speakers
I think x=27+12*rand(1,10000); will do the job for you.
//Magnus
» fs=44100;
» t=(0
» s=sin(2*pi*50*t);
» soundsc(s,fs)
//Magnus
That makes my head hurt! I don't even know how I got through diffiQ's wasted as I was most the time.
Sorry the only thing I have left in my head is fleeting bits of assmbler code and haunting thoughts of "who were those girls anyway?"!!
Magnus made me laugh though. Brought back a time when dealing with a pain of an architectural engineer in the dorm next door. Mix that with 400w's of drivability pushing a very faint 25hz through 4 18" woofers pointed directly at the dividing wall. . . . His entire finals weekend.
ok.........i have that 27+12*rand(1,10000) in my notes, but i was hoping there was a easier way....oh well
thanks guys...
and i'll be trying that sound matlab program....
space
thanks guys...
space
