mystery connector...eliminate?
During HVAC removal and...simplifying the wire harness...i discovered this guy hidden.
two of the wires are jumping to lines...should i just jump them together shorter up the road and eliminate the others that apparently dont need continuity?
red jumps blue and red/yellow
green jumps green and black/white
no numbers on the junction.
my car is an 85.5 N/A
im not sure...2 of the wires
yellow
yellow/brown gp into the door...but they are not connected to anything in the connector...so maybe its for an option on the door that isnt there?
the rest of the wires disappear into the harness behind the column, which i havent stripped that part of the harness yet.
yellow
Proceed with caution. Maybe pull it, then see if the car starts before going any further?
ok back to the car and i hope it atleast cranks...i have a lot of vac lines removed at the moment from when i eliminated emissions
well i put the cables on it, and i got a crank out of her. i didnt try for more because of all the vac lines removed, and i prob dont have much coolant in it after looping the heater hoses.
but i still have window power, and turn signals and brake lights...all i need right now...so off i go to eliminating more wires...
im just going to shorten those wires and keep the continuity there just to be safe.
and im not sure if i have a factory alarm? under the console is a 'clifford' alarm box, but its not plugged into anything, its just zip tied up there...i can see the wires its suppose to goto but...not gonna hook it up haha.
and after all this i have the hefty job of trying to wire up all after market gauges...which ive never actually done that before, so this should be interesting. ive always run stock guages with an after market boost and egt gauge...
oh yea heres the pic of the blower and hvac system if anyone wants to see.
it was easy to take out...easier than i thought. i thought it would be heavier, but i think all of this here weighs around 25-30lbs
I found that same connector yesterday while I was doing my reference sensor harness... but the black connector you have pictured was just ziptied to the wiring harness and not actually connected to anything. (and I couldn't find any plugs in the area that it would fit into) I do have the factory alarm but I've never used it so I'm not sure if this has anything to do with the alarm.
what reference sensor harness??
im still confused as to what these reference sensors do in the 944...or where they are...
found another weird thing...i think it has to do with the clifford alarm...that was never plugged in...
can i just cut this out??
it has black and white wires to it
then theres a...like ready light for the alarm? that has like purple and black running to it...
and for reference, this is all the wire i took out...so far
mostly done
mostly done
The wires in your original question are indeed for the factory alarm. I cut mine further upstream and soldered them together in the way yours are jumpered.
It cranks but does the tach work? It's a common malady that the tach wires which are hanging around the ECU harness upstream from the ECU get cut while you're doing all this. I know from experience! Judging by search I'm not the only one, either.
What about that big, heavy battery? And still factory strut mounts?
Looking good!
Cheers
Randy
Looking good!
Cheers
Randy
Looking good!
Cheers
Randy
Looking good!
Cheers
Randy
hmmm i didnt worry about a tach cause ill be wiring in an aftermarket one =D
