AC delete aftermath
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
I removed the condenser from in front of the radiator. Looks like the condenser took quite a number of hits over the years. And now my radiator is out there and vulnerable.
Does anybody put any kind of screen or mesh in front of the radiator to protect it? If so, I'd like to see some of your solutions of how you mounted it.
Rainman
FWIW ive had no ac condensor since 2005 and have not had any noticeable damage and the car has gone on many many long trips through dusty rocky areas, i even took it up from san diego to san francisco and back over the summer and the worst i caught with my radiator was a family of bees
hell, in december i went on a spirited drive on a twisty country road and annihilated a plastic basket someone had dropped in the street, stopped, picked out shards of plastic and the car was fine
Regular old fiberglass window screen double wrapped over a piece of wire shelving. It catches LOTS of bugs, stones, track snot, and has yet to let anything through. Cheap, lightweight, and effective.
What I did. I still run the condensor in front of the radiator though for added protection. I bought a "fin straightener" tool from snap-on to clean it all out and get better flow through
![](http://www.blackhillstools.com/images/AD3404.jpg)
Little black zip-ties mostly. Look closely. At the bottom I cut some slots in the supports and pulled the metal up into it. Easier shown in another picture I have.
Thanks for the ideas. You turbo nose guys sure have it easier. More points to attach it to. I'll think of something for my NA. I may even use the mounting point where the condenser went.
I decided to make this as complicated as possible. I made up a frame from aluminum angle stock and attached a screen to that. Then the whole things mounts up into the factory attachment points for the condenser.
![](http://www.enter.net/~stoogemoe/images/radiator_screen.jpg)
Now I'm protected !
Now I'm protected !
That's expanded mesh and while it won't come apart, it will easily stretch when anything of significance hits it. You may want to consider hardware cloth or real wire mesh. Hopefully what you have is steel and not aluminum.
