doh....new koni's don't fit into strut housing...
car is a california 83. original strut housing is labeled bilstein and is green colored. ordered koni 8641-1038. i guess i assumed it'd be a direct replacement...but obviously it can't be. i took the bilstein shock out and tried to put the koni in. won't fit. measured it. the bilstein body diameter is 40mm. the koni is 45mm.
bilstein strut:
so....help?
bilstein strut:
so....help?
bilstein strut:
so....help?
bilstein strut:
so....help?
they are koni 8641-1038 that i ordered from paragon for the early 944 application. by the paragon tech article, it looks like hacksaw inserts is for putting 8641-1414S into late model strut housings.....so i'm at a total loss what to do now.
Not Special
I've n'er done the conversion myself, but if you get early Boge struts you should be able to do the swap. Don't even think you have to do the hacksaw conversion.
well darren....then it sounds like the sooner u get the spindle off, the sooner u can ship it off to me :P
for now i'm gonna put the strut back in so i can at least have a garage to park in.
Not Special
You can have mine for shipping if I get the spindles off, but I know you're in somewhat of a hurry with an AX this weekend; doubt they'd make it to you in time.
yea shipping def ain't gonna make this weekend. i'm gonna make some calls tomm ... but the junkyards i typically go to wouldn't ever have a porsche. even if it is a junker from 25 years ago.
