DME Help Needed
Need some technical expertise: I'm trying to mix a 86+ engine (NA) & harness with a 83 chassis & DME. Any problems that I should be aware of right out of the box? Is the 86+ engine harness and multi-plug connector compatible with the 83 DME? Is the 83 air flow box compatible with the balance of the 86+ throttle system?
If it's used as a track only car, do I need the O2 sensor? or will it simply run rich?
I'd love to call anyone who is willing to talk directly... just send me a direct e-mail at dollmed@netzero.net
