Who has Europroducts chips?
If you've used Europroducts chips please post your opinion. They seem like an inexpensive way to enable 15 psi of boost. How's the mixture? In their Ebay advertisement they claim they increase the spark advance?? Don't most chips retard the timing to avoid detonation? I did a search on this and only found a few opinions. Anyone have dyno results? I'm looking for an off the shelf chip that's optimized for 15 psi and a mostly stock ride rather than one that's rich enough for say 17-18 psi. TIA.
I have used them, good improvement over stock, did not run them on a dyno. Have upgraded to a MAF and no longer use them. Make an offer?
<img src="graemlins/burnout.gif" border="0" alt="[burnout]" /> <img src="graemlins/burnout.gif" border="0" alt="[burnout]" />
I have a set. I've never driven another 944 turbo with just chips so I cannot compare.
I've ran from 11 to about 19psi on them with no detectable knock or ignition retard w/92octane pump gas w/(new)stock injectors, stock pressure regulator.
For some reason some people think europroducts are inferior to other chips, I personally doubt much is different (anybody who can show me something solid proving otherwise, please do so).
Ahmet
Ahmet
I have used Europroducts chips/shims with Lindsey BE almost two years.I have been satisfied so far.No problems at all.Performs much better than stock set up.
Olli
'88 951
Olli
'88 951
