Redline Rollbar - painted at home - pics
ya i see quite a few boards were put in place for backups haha. thats cool though, our junkyard here only uses TWO steelie wheels to keep cars off the ground which is pretty scary haha.
that came out pretty nice! excellent work roman!!
your stripping job came out way better than mine did! i had ALOT of glue to pick up, i had to end up grinding mine. You'll be able to see my job 2morrow hopefully as i ran into some snags finishing it up.
great work!
great work!
well roman, whatever gets the job done !! my dad use to use wood blocks on our VAN, thats when i just bought us jackstands. lol.
hankooks are a nice choice, but i still want to remain a mostly street car, and besides with a 3 speed, i wont be going anywhere fast anyway lol but i try.
i think autocross has some limits on coilovers and suspension upgrades...but not too sure. just focus on getting the car running !!!! that is what is important !!! just know that if and when you get frustrated WALK AWAY, dont linger or anything too much about it, just walk away and take a week off.
and plus, there will be other days that are nice, there will be many summers coming and more nice days so dont be discouraged about missing out a few seasonal days !!
ill take you up on that autocross roman ahahahaa best of luck and thanks bro
great work!
great work!
mine stalled because I can't take passenger seat out, I am not sure yet how we are going to take care of that problem, it doesn't move forward or back, just angles, and its in "far back" enough position so that none of the bolts are acessable
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
so I sprayed the rails with PB Blaster and we'll see what happens - the seats are intact and driver's side is like new, while passenger's side could have the bottom reupholstered
I'm using a metal scraper and a blade to get the glue off - going really slow so that not to damage the paint too much!
Kem - no problem, we were using some BIG blocks on the ML320 while doing brakes yesterday, HAHAHAH! we got them right under the frame so it was solid! I'm down for A-X, just let me sort this thing out!
Thanks!
Really all you need is cheap set from autozone. $40 for a set of 4. I use those and they work great, but boards are just asking for trouble.
ok so I took both seats out and conitinued taking out the carpet/sound dampening stuff
its so old in a couple of spots it took the paint with it down to the metal - I'll have pics up
there is a small dent/hole by the front jack point - I think the jack sliped and the car droped on it, or maybe someone used a jackstand and didn't know how to use it properly - in any case, the damage here is not that bad because car has rubber undercoating
now for a real problem: my passenger side floor is wet - but intact, no cracks or hole of any kind; however, my driver's side - which is dry - by the rear outside seat mount there are some nasty cracks where I can see right through it down to the ground - so I will have to atleast have someone weld something there
I need suggestions on what/how to deal with that part, can it be welded or a whole new floor is going to be needed? its just cracks around 1 corner and the mount started lowering down in that corner - for now - so I'm sure it can be filled/welded or whatever
maybe Jim or someone else local knows someone that can stop by with their welder and do this? I'm going to post it in our local forum and see
thanks - I have pics of what I did today coming up soon
No, not Mosquito!
Marc - how did you run the wire? or is there a kit for relocationg battery? I know that my "removable top" seal is probably really bad by now, that is where I think its leaking - when taking out side panels they were a little moist but not wet
here are some stripping pics from today - its about to start raining, so I am going to leave it untill its nice and sunny again:
Driver side view:
![](https://farm4.static.flickr.com/3319/3453361806_971b9c4cc4_o.jpg)
If you look here - towards the bottom - you can see one spot where its completely through and you can see the driveway:
![](https://farm4.static.flickr.com/3602/3452548003_0d63398162_o.jpg)
this is the one I need help with - patching or welding a new one in there?
This is where center console is - I want to keep the carpet around the shifter and stuff and that little pocket that's there - its kind of usefull so I'll leave it there (atleast for now) - going to cut and strip everything around it; what can I use to clean off this black tar? I've been using Un-Goo and a knife and its working allright, but I haven't tried it on the tar yet
![](https://farm4.static.flickr.com/3597/3453363280_1810082e21_o.jpg)
Passenger side seat mounts - look allright - these were wet, and tere was some standing water and PB Blaster down there (for when I sprayed to take out the seat) - I threw a rag on them and in a few mnts it was all dry:
![](https://farm4.static.flickr.com/3370/3452549369_67141b9c1e_o.jpg)
This is view from passenger side, back seat portion is so nice right now - I also cleaned out both wheel wells - forgot to take a pic, they are coming along nicely although there is some paint scratches now; also, interior panel - when removed (the one right by the door) it took a good ammount of paint wtih it - so I am guessing I'll have to spray inside of the car now anyways - especially if driver's floor needs some welding/patching:
![](https://farm4.static.flickr.com/3411/3453364964_4a641218f4_o.jpg)
So here's is all that was done today. Removing the seats was a real PITA - if anyone wants them I'm going to put them up for sale. Beware that the bottom sliding parts will probably have to be removed and you should get new ones (sliding part) - but the seat itself is intact and whole, no chunks missing or nothing
Driver side view:
BTW, we also fixed my E-brake - it wasn't broken, a piece that is making the clicking noise when you pull it up came loose, we put it back on an dthe E-brake is back up and working
oh, no, ofcourse not!
that reminds me - if anyone needs a pair of seats - my driver's side seat is perfect - it even slides! but my passenger's seat could be recovered on the seat portion, and it doesn't slide - it either needs a really good cleaning or to be replaced/fixed
I also have some door panels etc.
so long as we are on subject of seats and harnesses, which seats - or all of them? can be used with a 6-point harness?
woot, just did that, awesome
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
my dad came in and asked if I had sold anything, I told him to h/o a minute
I see some seats (like Sparco Evo 2) that have 4 slots for harnesses I guess this is the kind I need
