86 Turbo Valve Question
I'm not sure anyone can answer this but here goes. First of all the car I am working on has no history. From engine numbers I'm positive the block is not the original block. I'm having the head reworked and told the machinist that the exhaust valves were sodium filled. He called me today and said he thought the valves weighted to much to be sodium filled. So my question is does anyone know the weight of a stock 86 951 exhaust valve? Secondly were all 951 exhaust valves sodium filled?
The turbo head will have a "T" stamped in it. It is located on a flat near the head and block junction, between #1 & #2 cylinders. Close to that, between #2 & #3 cylinders should be a part number starting with 951...
Thanks OT I will check it out.
Josh here are some block numbers
M44.51 2,5L 4 1986 Porsche 944 TURBO (162Kw / 221Hp) 45G00001 >> 20000
M44.51 2,5L 4 1987 Porsche 944 TURBO (162Kw / 221Hp) 45H00001 >> 10000
M44.51 2,5L 4 1987 Porsche 944 TURBO (162Kw / 221Hp) 45J00001 >> 10000
