Mixing solid and rubber trans/motor mounts
Good Day,
Opinions needed on using solid transaxle mounts with a motor on rubber mounts. Though the transaxle will still flex a bit, I'm wondering if there would be any issues with having one solid end and one flexy end. This is for a street-driven car.
Thanks.
Thanks.
Anyway, my N/A has been this way for 20K or so mileage wise, and no issues with driveability or maintenance... but she is broken right now (I suspect bad oil pump or bad lower balance shaft bearings...) but need to fix the Turbo first...
Solid trans mount firmed up shifts nicely...
When I had to replace my tranny I filled my tranny mounts with windshield urethane. It made them quite stiff. I have noticed little difference. There is a little bit less wheel hop, but I still need my suspension redone.
http://www.pelicanparts.com/cgi-bin/...20(1982-1%2F85)
I think these are the closest you will get to solid on early..
Rainman
Herr Unmöglich
Will find out soon. I have the Lindsey solid trans mount but OEM motor mounts. Figured I might as well use them til they blow before buying solid motor mounts too.
