S2 Throttle Body Coolant Elbow
My 1989 944 S2 lost coolant yesterday. I found the leak to be from a plastic elbow that goes into the throttle body. The elbow had come out of a hole in the throttle body. So I need to know:
(1) is the elbow glued into place or is it just a force fit and
(2) If it is glued then what is the Porsche recommended adhesive.
--Roy--
--Roy--
It is friction fit. You can try to use jbweld to epoxy it back in place.
The easier thing to do is to use a piece of tubing to bypass the throttle body entirely. Not necessary except for long full throttle runs (like on the autobahn) primarily to heat the TB to prevent icing.
