How to remove the rear seat?
So ive tried search to no avail, so ill ask. How do i take out the rear seat in my 924s? I haven't been able to find much on it.
Hey Man
I assume you are talking about the lower sear? The top just unbolts at the sides. For the lower section there are several clips between the leather and a raised flange on the rear deck; you can see these after the upper portion is removed. Remove the clips; the seat with padding is just glued in place as a unit with typical German pig snot glue. I just slip my hand between the glued down foam and metal. Work your hand side to side and lift as you go. It comes out pretty easy if you don't try to tear it out too quickly. Here's a pic with upholstery stripped from both the upper and lower.
![](http://forums.rennlist.com/upload/pt4_copy4.jpg)
