Dangling Parking Break Cam
I have a noise in the right rear which sounds like the CV is going out. After removing the wheel and disc I found the cam connected to the parking brake cable very loose. It was essentially dangling inside the hub but still connected to the cable. Also, the slack in the parking break cable on the right side is excessive.
Any way to tighten this gizmo?
Thanks,
Thanks,
