"Rattling" Exhaust? and "Crunchy" Shifting
Okay, I've been living with this for a couple of weeks since I had my clutch replaced and it's bugging me.
I think my wrench was hurrying and left something slightly loose. There is a distinct rattling noise at idle that clears out us off idle. I haven't bothered to look because it's dark every night when I get home and the car is too hot to start touching the exhaust system. I'm hoping to fix this over the long weekend. Anyone experienced this on an NA? Advice please?
Second, also since the clutch job I don't think the shifting is quite correct. There is no way to describe it except "crunchy". Not too objectionable just not smooth -"snick-snick" like it was before. I asked the wrench, he looked it over but said there is little to adjust, nothing he could find. Advice on this? It is the stock shifter. Thanks in advance guys.
One way to find exhaust system vibrations is to try tapping the exhaust in various places with a rubber mallet. If the pipes are too close to something (like the heat shielding), the vibration from the hammer hits will isolate them.
Ferd
'86 NA
Ferd
'86 NA
It's possible your clutch isn't disengaging fully when you press the pedal. Your wrench may need to bleed the clutch system again, if there are air bubbles in there it could do that.
Thaddeus
Thaddeus
I have the same sort of exhaust rattling on my 944 NA and I had the same thing on an Acura Integra I had. On the Integra it turned out to be loose crap in the catalytic converter making noise when the car was cold. Once it warmed up, no more noise. I replaced the exhaust and it still made the noise. Replaced the cat and it was gone.
Everything on my 944 is securly fastened so I believe its probably a similar problem although sometimes the rattle sounds like its coming more from the muffler area rather than the cat.
Since they did totally remove the exhaust system when the clutch was done they "could have" dropped the cat causing crap to break loose and rattle. Dammit! I was hoping it would just be a commonly known (by you guys!) heat shield or interference and five minutes with a socket would clear it up. What does a $%@#$ replacement cat cost?!!
Never thought of the idea of air in the clutch hydraulic system. It feels more mechancial to me, but that could still be true with the bleed problem. I'll look into it. Thanks agian.
Check the heat shield attached to the starter with a rubber mallet. It can stress crack and rattle, even if it's tight. You can weld up the cracks, but I found they eventually will fail again, so I fabricated my own starter heat shield.
The rubber mallet is the best way to isolate a rattle. Hit everything under the car.
Cheers,
Cheers,
Hey, look at it this way.
I changed my clutch and now have a rattle that I can't find and my wheel bearing is going out. Not sure yet how the two are related... still digging for answers!!!
Make sure all of the rubber donut hangars are in place on the exhaust. I had a rattling exhaust when I first got my car. Turned out there was one of these things missing.
Since the exhaust had to be dropped, there may be one that was missed.
