944S Camshaft?
944S Camshaft?
Where can I find camshafts for 944S for sale for good prices? Do you guys know of any website where I could find this?
I need to buy exhaust camshaft... it's abit expensive here at Porsche dealer in Iceland. (1.305dollars)
Also, I forgot...
Does anyone here know about 944S2... I was thinking of buying new injectors, I think injectors in the car are beginning to fail. If I buy new ones, how big... ? And the same flow as the original. There's no need of getting bigger injectors right? If the car has no modifacations (only K&N filter).
Administrator - "Tyson"
In 1999 I needed a set of cams (cam chain broke). I found a few used sets around the country, all were sent back due to excessive pitting. My original cams had over 100,000 miles, the lobes looked new so I had no reason to accept pitted cams.
I ended up buying new cams from Porsche, around $900 each.
Hugely expensive...
I wanted to put exhaust camshaft from an S car into my S2... deliveres a litle extra power.
But hey, I see you have supercharger kits for 928... do you have kits for 944S2?
The Impaler
The Impaler
The engine is apart in my basement, tearing down the head for a good cleaning after a rod bearing...
I'm probably going to send out the piston / valves / heads to have all combustion parts coated by swain tech for future boost.
First step will be converting the ECU to AEM or Autronic, then boost.
Also, I forgot...
www.speedforceracing.com is the website for SFR.
I've heard that www.944online.com can rebuild 944S cams that have broken sprockets. I'm sure they have a few rebuilt cams for sale.
IF you do end up investing in brand-new cams from Porsche, I would highly recommend reinforcing the tensioner on the rear side by making a mount on the #3 spark plug hole. The S and S2 weak point is that the tensioner breaks off from spark plug hole #2 and it destroys the cams and everything else!
I don't know if shipping and duties will cost too much, but maybe Sunset Imports in Oregon, USA can get you a better price?
The Impaler
As far as EMS, I'd just get a vitesse MAF/piggyback... that's the cheapest solution anyway, and it works wonderfully.
