944 Oil Pan
I think there are some posts concerning this issue on the board. Try searching for them. I think (never done this myself) that the process involves raising the engine up to allow for extra clearance. I believe that you can jack it up from the bottum and then brace it from the top with a 2x4 (or something similar) across the fenders ... watch the paint though, remove the jack and you should have enough room to drop the pan.
Try searching the forums for oil pan gasket or something similar.
Might as well consider replacing the rod bearings while you have it all open (they're less expensive than the pan gasket). See the tech session on this at Paragon Products web site.
If you have over 100k on the clock and/or track the car, it's worth doing. Plus, it's all labor.
Keep the shiny side up,
