Power Window Delete, retain glass window
I wanted to delete the motors on my track car. I also needed glass in the doors as the car is stored outside. I also wanted to not pay for Lexan or even cheap Plexi so I devised a way to attach a strap to the OE glass.
Pics and details at my blog.
http://kevingosselin.blogspot.com/20...ow-delete.html
Paragon sells a kit that is like $200 a side to add a crank.
Yeah, you just raise the strap to raise the window. I will most likely just take the whole window out while on the track. No need to have it rattling around in the door.
Strap it to a dyno?
All I did was a pull in third gear from 2krpm to 6300rpm with my modest 276whp/300wtq. I just looked at the time marks on the run chart and realized thats how fast it does it, which I then posted because it sounds more impressive than just posting the power numbers.
This was the highest power pull, but not the fastest. 8.2 - 4.7 = 3.5 (time is the bottom/horizontal scale)
