Installing a Boost Kit - Couple Questions...
I think I'm done with engine 'upgrades' after this. I want to keep the car pretty stock. I'm quite happy with the power now and the engine runs great so I don't want to mess with a good thing...
yeah, my research pointed me to the Lindsey 951Max chips over just about anything else - particularly the autoauthority ones.
I'm looking forward to getting started on it. My only question mark right now is the vacuum hose on the firewall side of the FPR. The Bosch in the kit's male end is about half the size of the existing tube that's connected. I'm not sure what I'm going to do about that...I think I'm just going to have to remove it and see what's going on and determine what size tube I need.
+1 on the vacumm kit upgrade, it makes everything easier. Also if you have time I recomend running a new line to the KLR, it just helps clean things up a bit.
Good luck!
Good luck!
