Spark plug size???
For an S2, and I don't mean heat range, electrode length, gap, etc. I mean, I've got 19mm and 24mm deep sockets, and the plugs are somewhere in between. ![Confused](https://rennlist.com/forums/images/smilies/confused.gif)
I only want to make one trip to Sears - what size do I need to buy?
Thanks,
Scott
Thanks,
Scott
Just a car guy
Be sure to get a proper spark plug socket. It will have a foam cylinder inside it to gently grip the ceramic insulator of the spark plug so you can pull it out of the hole. 3/8" drive is desirable.
13/16" eh? My standard (non-spark plug specific) 3/8" drive deep socket won't fit into the spark plug well in the head, so maybe a 13/16" spark plug socket has thinner walls? I'll have a look-see at Sears today - thanks for the responses.
So, which one is it??? I'm heading to Sears tomorrow myself... Is it a 13/16 or 3/8?
http://www.sears.com/shc/s/search_10...rk+plug+socket
Standard spark plugs are either 5/8" or 13/16". In the case of the 944, it is 13/16"
