One piece OPRV better?
#46
looks like you have to remove the oil cooler to get it out?
#47
I'm also worried I stuck my finger in the hole and I got a piece of thread broken off in there out and another piece fell in there..... looks like the threads in the housing had stripped off one part.
I checked 944online which usually lists any part you'd need and that sleev is not listed there so i'm not sure if the dealer would have it.
hmm that pic you posted looks like he is removing and installing the sleeve with teh oil cooler in the car installed, that's why it didn't look possible to me.
also will I need the special porsche tool to install the sleeve?
i'm not going to run my engine any longer and just park it till I can get the oil cooler out then figure out what to do.
you don't have to drain oil to do the oil cooler right? I just put in new oil crap.
also can the oil cooler be removed without removing the exhaust header...... I really don't want to try and remove the exhaust header with rusted on studs and nuts that are likely to snap.
and last question lol, how big of a job is an oil cooler replacement and how difficult is it to do and how many hours?
it looks easier than some of the other stuff I had to go through like trans removal and oil pan gasket replacement. The instructions are a little confusing though in clarks, with measuring how many spacers you need.
thanks.
thanks.
#48
Hey Man
I just checked the sleeve on my 951 block. It does not move at all and with the housing on the end is over 1/2" away from the threaded section of the housing. If your sleeve can move as far as the threaded section then that has to be a big part of your problem with intermittent oil pressure. I hate to tell you but the oil cooler housing has to come off and the sleeve will need to be replaced, or at the very minimum, checked, sealed, and reseated. There is no way the OPRV piston can work properly if the sleeve slides with it during operation. Sorry for the bad news.
Post a request for a used sleeve if you can't find a new one through the dealer. There are a few trashed early 944 blocks around here that can't be used for anything but a coffee table base.
#49
my orv piston is smooth and not scored and spring is not broken so there can't be anything else wrong with it, however the sleeve in the oil cooler where the piston rides in is loose and moving up and down and that seems to be causing the problem.
so for now it looks like I need a new oil cooler seal kit and a new sleeve and figure out how to replace it.
will I also need the 83-86 allignment tool if i'm using the three piece oprv? I will have to first fix (replace) the what seems to be broken sleeve in the cooler housing before dumping 400 bucks on a new oprv which may not be the problem.
I work and go to school everyday though so this repair will probalby take me 3 weeks or so.......
#50
Check ebay etc for a used 1 pc updated OPRV. I picked one up for ~65 about 2 years ago.
If you've done the belts,trans,oprv, etc you can handle the OPRV/oil cooler. You sound like my friend who owned a 944. he loved it and after learning how to do the work could do it no problem (belts, waterpump, head gasket, wiring, etc) ........but just got frustrated with having to work on it/put money in it and gave up. Every time I let him drive my 951 he is kicking himself in the ***.
stick with it!
stick with it!
#51
thanks Kuhl 951. well I'm kind of relieved even though teh oil cooler has to come out...... at least the oil pan doesn't have to come out lol, or I didn't sin a bearing yet.....
oil cooler seal kit is cheap but I'm not looking forward to replacing teh oil cooler housing and seals it looks messy and a pain in the *** to do.
does my exhaust header have to come off.
what is shop time for this job? if it's like 3 hours I may consider paying to have it done as it'll take me 3-4 weeks most likely, working on it like once a week.
#52
yeah gets frustrating when you want to go out or get to work or class and now you can't go out because the car decided to break again.
tom I have to bus to work......
my fault though I'm the one that decided it was a good idea to make a 23 year old porsche my daily driver.
everytime I do a repair I say " alright it should be reliable now" and then something else breaks lol.
#53
stick with it!
stick with it!
Mike you can't just stick a used oprv in the 85.5 or pre 86 cars. They use a shorter update version to replace the 3 piece units.
anyways I have a feeling that it's not the oprv itself causing my problem but the loose and moving sleeve. sticking a 400 dollar updated oprv in a moving sleeve will likely do no good.
#54
"used 1pc updated OPRV"
I had 2 early N/As with many of the same problems you've been having. I know the OPRVs are different (if you searched you probably saw my threads about this a few years ago) but the thread is updating so fast I was not aware of the sleeve issue. Take it apart!
It's not that bad, have you had your exhaust manifold off recently? Getting them off is really the hardest part.. although you can work "around them"
#55
never had my exhaust manifold off. is it absolutely necessary to get it off?
if soo I'll soak it in pblaster.
i'm going to order the seal kit I need from paragon and drain the coolant and saok the bolts in pb blaster this week then I'll begin to take it apart next week when I have time.......
is it just me or does a 944 take all your spare time and money to keep running?
it's like a drug addiction, I know it's bad for me but I still want it and spend money on it.
#56
I am now worrying that a small piece of metal fell into that oprv hole and could have been pumped into the oil system. when I stuck my finger in the hole I got a small piece of broken metal (one of the threads in the housing that the oprv botl end bolts onto had broken off. I felt another piece in there also put couldn't get it out. I did test run the engine aftewards to see if I go toil pressure then shut it off.
#58
Also I would contact George Beuselinck at http://www.944ecology.com/ about the sleeve. He is a great source of used hard to find parts.
#59
You should be able to get the housing off with the headers still on the car. It will be tight, but should happen. I did this job many years ago so I know it can be done.
