wtb 951 oil pan in vgc
i'm looking to buy an oil pan in very good condition. i figure since i'll have the cross member dropped for some other work i'll replace the rod bearings and baffle the pan. im pretty sure someones got one laying around. any other suggestions while im down there (i'll be putting in a new rack w/ hoses and resevoir, motor mounts, updated oil cooler seals, and sway bars)? thanks
Done With Sidepatch
IS there a problem with the pan you have? I have a couple of pans from '86 951's...If you wanted one with all the fins intact then I can't help you...These have a couple of chipped cooling fims otherwise all is good...
no nothing wrong w/ my pan, i just want to have the baffled one on hand so i can drop, replace bearing, clean the sump, and put back up. i doubt it will go that easy but i can just hope for it.
i'd like one w/ the fins intact if at all possible. thanks
