MaxTune users...
I was looking on their website and searching threads but couldn't find the answer.
In the software there is a tab labeled "auxiliary maps." Which maps are editable? The website mentions the intake air temperature compensation map but what else does it include?
Stephen
Stephen
You can edit the FQS scalars, rev limiter (fuel cut off), and temp correction.
I would love to be able to use my maxtronic, but I sent it back to russell as it was flaky and don't have it back yet... seems like an awesome program
I found out a bit more from someone who works closely with Russell. Apparently there's an IAT correction map of some type (2D, 3D?) and adjustment to the FQS scalers.
I *know* however that there must be an AFM translation table in there somewhere as the AFM outputs are drastically different (in linearity) between early and late cars. Maybe I should just get a BIN and start looking for everything other than the standard set of maps. I'm sure (and I doubt any tuner will admit) that they've run across data that they "don't know what it does."
Maybe a Hitchhiker's Guide to the Motronic Maps....lol
Stephen
Stephen
fwiw, everything in the aux. maps is 2D
what are you looking to do?
re: AFM outputs. On the "configuration" tab there are map/image offsets, and an "AFM transfer" that may have something to do with what you are looking at. I don't quite understand it. I don't think you can edit them, but maybe you can in file mode.
I'm curious, if the IAT correction map is 2D, exactly what is it referenced by? Is it compensating for ignition or fuel and it just a simple RPM reference?
The German engineer in me wanted to develop something a bit cleaner / more elegant.
Stephen
I think I'm going to go ahead and actually go through the Probst book cover-to-cover.
Originally Posted by Fast924S
Im running maxtune and the maxtronic on my NA, LOVE IT, Im running it with a Huntley Racing MAF setup, Works fine
Stephen
'86 944NA
No dyno numbers yet, Gotta wait till spring, to much snow right now. Im using both the ARC2 and the Maxtronic, I havent figured out how to run the MAF just on maxtronic alone, Since Huntley Racing isnt around anymore its really hard to found out info on the MAF unit. But for now it works, I dont use the ARC2 to make adjustments anymore Just the Maxtronic, Only time the ARC2 needed to be retuned was when it got really cold or really hot, Like maybe a 30 degree difference from when the tune was done, But its easy to retune, Since I have installed the Maxtronic I havent had to touch the ARc2 at all, Soon I will have a wideband 02 installed so I can see how things are, But so far so good
I had the ARC-2/Maxtronic combo until my maxtronic **** the bed. I've been dying to get a replacement so I can actually tune my car...the ARC-2 is way too crude and I can't get it 100% drivable. I was planning on using the maxtronic to tune but I still don't have one back
Seriously considering going w/ the vitesse MAF kit
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
It misted last night but everything's drying it; it's sunny and about 64 degrees. Later it will just kiss 70 and I'll be out driving with the roof out
This sort of confirms what I thought was going on with the ARC2 and the ECU. Nothing like experimental results. I'm really excited to see where you end up, power-wise.
I think you'll find the wideband indispensable for really seeing what's going on. One of the biggest problems with the stock ECU is it's lack of self-adjustment. The O2 sensor (if you don't have a Wilk chip) really has very limited effect on final mixture. With a Wilk chip there is no effect. I think this is a big reason why people bolt stuff on and it doesn't do much. These cars really need custom tunes when you start messing with them...even the NAs (turbos that's a given).
Stephen
86 944 NA
02 Subaru WRX modded
Yea i wish it was nice here, but ill have to wait, I noticed a huge difference when i loaded the 93 octane maps, I think your right about custom tuning, with the NA's its all about timing advance and compresion ratios, with the 1988 10.2cr pistons I installed and the 93 octane maps it really makes her pull. Cant wait to play with it some more. Still gotta get it threw emissions, lol
