No squirt
From: Brisbane, Australia (Formerly: Sunnyvale, CA)
No squirt
My windscreen washer on my S2 has stopped squirting. Hadn't used it for a while.
What's more likely -- a blockage, or the the little squirt pump has failed? Is there a fuse or a relay to check?
Where _is_ that little pump, anyway? I couldn't spot it looking in the bay.
-Mark
-Mark
Finally got my squirt back. The little squirt pump had failed. Replaced it this evening.
The pump is tucked into a moulded bay to hold it on the bottom of the washbottle... on an S2, anyway.
