S2 timing belt job
Unfortunately you need to replace all that crap on the front of the engine that you can. I think that covers it! Ok more detail. Replace all the seals, crank balance shaft etc. Also on my 968 there are little metal colars on the balance shafts that need replacing as well. The water pump is an integral part of the cam drive system and absolutely needs to be replaced! By the time you replace all the rollers, you have spent some real money, but you will be rewarded with a good running car that probably will not leak. You can also be confident that valves will stay away from pistons!
I've used a place called BMA in Burbank, CA they do internet sales have good prices and use OEM parts. I'm sure they can get the kit, or put one together for this car.
Did anyone notice in the TB posted earlier that it doesn't say to roll-back the engine at all (1.5 cam teeth, x degrees)? I recall that the FSM and clarkes say to do that, and it definitely affects the belt tension reading (Slackens the belt). Any experts have the scoop on this? Thanks...
Location: Brisbane, Australia (Formerly: Sunnyvale, CA)
Is there a resource that describes the timing belt tensioning procedure just using the spring tensioner? In particular, what tools are needed? Presumably, you can dispense with the thin wrench, the 9201 (or equivalent), but still need a flywheel lock? Any other special tools required for this method?
You can make do without a thin wrench, but I have found that for the S2, a collet wrench for a router is the same size as needed. The flywheel lock is a must, just because you need it to hold the crank when applying the 150ft-lbs to the crank pulley.
Looking at the diagram, it's not obvious to me how you do this. Looks like it's the spring or nothing -- what do grab hold of to do a manual override?
Not stupid at all. The spring arm moves against the belt until the tension in the belt is equal to the spring force; at that point you lock the arm down and fix the point of the roller. Take a reading and decide if it is good or needs adjustment. If the belt requires more tension, then you loosen the lock down bolt and apply additional load to the arm to tighten the belt further and again lock it down and take measurements. If the belt is too tight, then you do the converse and just back the arm off a bit and again lock it down and take readings.
When doing this I would just push against the roller increase/decrease the load.
Good Luck!
Good Luck!
OK, thanks guys for all the insights and pointers; I now feel like I've got enough info to formulate a plan.
So, looking closely at the service records, I've decided to just do the belts, rollers and seals (except maybe the cam seals, as Bruce Arnn says on his site that removing the cam gear is a pain, and it rarely leaks from there anyway.)
The water pump was replaced 56000 kms ago (about 35000 miles), the timing chain 34000 kms ago (about 21000 miles). So I suspect they've still got some life in them yet.
The rollers, apart from one of the balance shaft rollers, may never have been replaced since new (173000 kms, or 108000 miles). Hard to believe, as the records show the belts being replaced at the correct intervals, but since the rollers don't get mentioned (except for that one time) in the fairly detailed records, I feel I have to assume they are long overdue.
For tools I've bought the flywheel lock, the pin wrench, the 27mm thin wrench (all Arnworx tools), and a kriket-1.
The only outstanding issue at this stage is what are the correct belt tensions: Clark's garage and Bruce Arnn don't seem to agree. Here's a summary of what they say:
Arnn's unit are described as lbs, and Clark's garage don't specify what their units are (I assume 4.0 is 40 Lbs).
Which site is more uptodate with respect to the Porsche factory recommended specs?
Code:
clark's arnn's timing new 4.0+-0.3 40+-0 timing used 2.7+-0.3 37.5+-.5 bal new style 3.5+-0.5 27.5+-.5 bal old style 2.7+-0.3 not mentioned
When I do my belts with the Krikit, I use 40 for the cam belt and 28 for the balance belt.
Some more good info on how to use the Krikit is here:
Marcus Blaszak Webpage
Riff,
Thanks for that -- looks like you're in broad agreement with Marcus Blaszak and Bruce Arnn on this.
(That Optibelt tool looks _very_ similar to the Kriket, doesn't it?)
What value do you use when retensioning the T-belt? Arnn's 37.5 or Clark's 27.5? (Seems like a big difference!)
Also, I assume the B-belt is simply retensioned to 28 if it has streched at all after 4000 miles (or so.)
-Mark
-Mark
...I don't believe he would adopt this viewpoint without some basis.
Bruce
PS.. I love the idea of the krikit but I think it is little like trying to read a millimeter with a yardstick.
PSS.. the Clark reference (4.0) is using the factory tool, different measurement system than the krikit. Theoretically the two values represent similar belt tensions though.
Suppose 4.0 = 40 lb (timing new)
Suppose 2.7 = 37 lb (timing used)
But also
3.5 = 27.5 lb (bal new style)
This would mean that 2.7 on the 9401 corresponds a higher tension (37 lb)
than a reading of 3.5 (27.5 lb)
This is just silly, of course.
Further, you will notice that the recommended values on clark's site (which were taken from a version of the wsm originally, I'm not sure what date) suggest a used timing belt should have _less_ tension than a new style balance belt, whereas the values published on your web site suggest the a used timing belt should have significantly _more_ tension than a new style balance belt.
To quote Elmer Fudd "somethin' scwewy goin' on..."
Code:
