Update on pinging/knocking...
Well...after pulling everything apart, I found that there was a split vacuum line that goes from the bottom of the throttle body to the temperature valve under the untake manifold at the back of the engine. I thought I'd found my problem... HUH!! I replaced the hose - no difference, except the temperature valve should work better now - hows it work anyway?
My next step is to clean the injectors, and change the fuel filter. I will also be odering a Fuel pressure gause to mount on my fuel rail.
Can anyone tell me how I would go about cleaning the injectors?
Thanks...
Thanks...
