HELP!!!!!!! not much time left.
Old 11-30-2008, 11:45 PM
WizPorsche944
WizPorsche944's Avatar
That seems normal.
Old 12-01-2008, 12:54 AM
JohanvdWalt
JohanvdWalt's Avatar
Jip thats perfectly normal, it can even go up to the third white line but not above it.
Old 12-01-2008, 12:55 AM
medevack
medevack's Avatar
ok i checked the radiator hoses and the top one was warm/ hot and the bottom one was cool could that be the thermostat?
Old 12-01-2008, 02:43 AM
porshhhh951
Monkeys Removed by Request
porshhhh951's Avatar
Honestly I had the same problem on my 83'. It ended up that the fans where not coming on properly. My mechanic just hard wired the fan and it was on all the time and it went away.
It could be many things but, i'd check to make sure your fans are turning on properly.
Old 12-01-2008, 02:45 AM
medevack
medevack's Avatar
i have the fans wired up directly so they are on all the time.
Old 12-01-2008, 02:53 AM
porshhhh951
Hows your thermostat?
Old 12-01-2008, 05:55 AM
JohanvdWalt
That certainly point toward the thermostat, might be a blocked radiator too. I would start with a system flash. It could be the pump and the seal behind the thermostat is also a likely cause. Lots of people replace the thermostat but leave that seal in place and then it came back and bite them later.
Old 12-01-2008, 07:41 AM
medevack
medevack's Avatar
ok the water pump is new im guessing the thermostat so ill start with that and a flush.
Quick Reply: HELP!!!!!!! not much time left.
