Found: Correct tool for removing pins from mirror connector (AMP 305183)
Old 12-01-2008, 05:10 PM
  #31
KuHL 951
Hey Man
KuHL 951's Avatar
Originally Posted by ModdedEverything951S
Just for archive purposes, the AMP 305183 is the tool to remove the pins from the connector. Took all of about 2 minutes and then messing with the wires to get them out. Thanks Colin!
SeaCay, did you get my PM?
Thanks to both of you guys for posting the correct tool. My phone suggestion yesterday to Darwin about using a chainsaw was soundly rejected.
Old 12-01-2008, 05:17 PM
  #32
Darwantae951
Darwantae951's Avatar
I don't know. I ALMOST took a chainsaw to the entire car! Hey Steve, if you need one of these things, lemme know. It'll make your aero mirror conversion a TON easier!
Old 12-01-2008, 06:35 PM
  #33
KuHL 951
Hey Man
KuHL 951's Avatar
Thanks but I just ordered one from Newark Electronics, $12.75 after my discount and I can pick it up about 5 blocks from work. I wonder if it also works on the sensor, AFM, and injector connectors? It's too large for the DME plug I think.
Old 12-01-2008, 09:13 PM
  #34
SeaCay
Thefu
SeaCay's Avatar
Too late I'm afraid.
Old 12-01-2008, 10:56 PM
  #35
Darwantae951
Hey SeaCay, I'm going back tomorrow if you need one. I'm picking one up for another lister.
Old 12-01-2008, 11:22 PM
  #36
Darwantae951
Anyone else need one, just shoot me a PM. I can get them to you guys for $17 shipped.
Old 03-05-2012, 08:14 PM
  #37
GlenL
GlenL's Avatar
Got this from Newark, $20 delivered.
44F8408 1 In Stock 12.52
Extraction Tool; For Use With:Type II, III, III(+), VI, X, & Subminiature Coaxial Contacts; Tool Body Material:Steel; Body Material:Steel & Plastic; Color:Black
305183 TE CONNECTIVITY
Old 03-07-2012, 11:49 PM
  #38
Mac 86 951
Mac 86 951's Avatar
Default Digikey another source
We use these all the time at work (electronics place)
You can find plenty at Digikey too.
Old 03-08-2012, 12:03 AM
  #39
elzergone
elzergone's Avatar
Can someone explain to the clueless what this tool is used for?
I always try to catalog this stuff away in my brain for when I inevitably need it with this car.
Old 03-08-2012, 02:33 AM
  #40
azbanks
Freedom Enthusiast
azbanks's Avatar
If you want to replace the 944/951 mirrors with 968 mirrors, you have two choices, cut the wires or remove the wires from the connector.
These tools allows you to disconnect and reconnect the wires without cutting them.
Old 03-08-2012, 05:35 PM
  #41
elzergone
elzergone's Avatar
Ah gotcha. Thank you!
I'm one of the few who really like the flag mirrors so I guess I wont be needing to remember that one
Old 03-08-2012, 05:51 PM
  #42
black944 turbo
black944 turbo's Avatar
It also allows you to take apart your mirror when the pin falls out and you have a hanging mirror. I wish I saw this thread 5 years ago as I spent $100 labor for my local shop to pull the pins and put the spring and collar back on my flag mirrors, just to keep from cutting the wires. I am still mad about that.
Old 03-08-2012, 07:19 PM
  #43
elzergone
elzergone's Avatar
Wait so this is needed to remove the mirrors AT ALL, without cutting the wires?
Old 03-08-2012, 07:39 PM
  #44
black944 turbo
Yes, you have to pull the pins to pull the connector through the body of the mirror.
Quick Reply: Found: Correct tool for removing pins from mirror connector (AMP 305183)
