944 Turbo HP kit on Ebay
FYI,
I just listed a Kokeln Stage 3 Turbo, Kokeln chips and DME/KLR on Ebay. Item no. 2418863729. Add an aftermarket wastegate and an adjustable boost control and kick some butt!!
Eric
Eric
"Don't trust the chip makers results. Mine are dyno proven!! 1986 stock motor had 204HP and 186 Tq at the rear wheels. After installing the computer and Turbo it went to 247.4 HP and 250.2 TQ. "At the rear wheels!!"
That's a pretty big statement. 204hp on your 84 944? Running how much boost before and after? What type of dyno?
That was what I was quoted from Dwayne Dement owner of Vision MotorSports. I'm not sure what the dyno was but my motor was stock except for a knife edged crank. The seconf set of figures are after installing the chips and Turbo. Again from Dwaynes own notes. When I bought the car it also had a dual port wastegate and a manual adj boost control which the car was set at 16PSI and it was hitting 286 RWHP. If you have any questions about the setup feel free to call Vision MS in Laguna Hills.
Eric
Eric
Yarin,
You are right I need to change my Ebay sale. Stock was 191 HP and 212 TQ. If you go to <a href="http://www.kokeln.com" target="_blank">www.kokeln.com</a> and check out the 944 Tubro the R&D car is the car I purchased. The 247.4 HP was done with the Turbo, Chips but no air filter kit. Sorry for the confusion and I am going to properly update the Ebay now.
Thanks,
Eric
Thanks,
Eric
