DIY Throttle Cam Writeup!
I didn't notice all that much difference, but if you're curious, there's no reason to spend $35 on one...Questions, comments, criticisms...
<a href="http://209.6.126.158:8000/944/throttlecam/throttlecam.htm" target="_blank">Throttle Cam Upgrade</a>
Hell, you can steal and post it as your own for all I care. I'm here for the people Address should be:
<a href="http://209.6.126.158:8000/944/throttlecam/throttlecam.htm" target="_blank">http://209.6.126.158:8000/944/throttlecam/throttlecam.htm</a>
Ah, it currently changs sometimes, which is annoying, but I'm working on getting an actual domain...
Tremelune-
Thanks, just did this in about fifteen minutes, I also used a Dremel to grind down the spot on the arm where it catches the ridge--SMOOTH. I actually love how this feels now, LINEAR. I think it's much easier to modulate exactly how much gas you want. Thanks again and if I ever feel like I don't like it I'll take all of two minutes and switch it back!
