PS pump rebuild
Running ok, still have not fig'd out the full boost/WOT issue. A few others are having the same issue, so waiting to see if they fig it out - lol.
There used to be a video somewhere showing you how to seal the pump, but looked on Arnnworx site, and Rennbay, didnt find it anywhere. Maybe someone put it on youtube?? There are a bunch of seals in that kit that u won't use as the "KIT" is for a 928 pump. See if u can find it.....
alright, ya i got it mostly finished, just cleanin thehell out of it. but that piece under the c lip, you know how it has all those little square things, well one side has a rounded edge and one side has a flat edge, which side faces out?
Well I found the video too
ANd its travis talking lol
http://rennenkauf.com/kauf/index/listings/page203.htm
If I remember correctly, the rounded edge faces out.
Be sure to tug on the shaft (no pun intended) to be sure the pulley is being held in by the c-clip securely. Mine worked it's way loose at the track. I guess I didn't get the c-clip in right. It pretty much ruined my pump...and my weekend.
You know, i wouldn't have laughed or even though funny thinggs about you sayin tug on the shaft until you said no pun intended lol. But ya i will make sure. Does it really matter if they go in either way?
As has been said, rebuilding the PS pump is unbelievably easy.
Rounded edges go out on the little squares, and make sure the c-clip is on properly. Other than that its just a matter of clean, clean, then clean some more.
