who has installed a replacement dash?
Just like the title says - I'm going to tackle this project in the next week or so and I'm wondering if anyone has any insights/tips other than the walk-through on Clark's Garage. TIA.
not offering any advise, but just wondering where in the DC area are ya? And are you coming to the meet on Sunday? Good luck on the install! I plan on doing my dash over Xmas.
Also is the car airbag equipped?
I'm in DC proper. The car is also about to get a suspension overhaul, so it's not on the road right now. I'd like to make a meet in the future though. The existing dash and replacement dash have the passenger side airbag (disconnected, I believe). The steering wheel has already been replaced. Thanks,
Alex
Alex
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
Done it few times -- not that hard to do, except there are lots of screws to keep track of. I would get a roll of Scotch tape and tape the screws to the print-outs of Clark's Garage.
Odd Posts
I have done it and if you follow the Clark's Garage instructions it will go very well. Be careful with the older plastic parts as they can be brittle. I used ziploc sandwich baggies for the fasteners and labelled each one with reference to the instructions and location.
While you are in there I recommend replacing all of the bulbs (with LEDs) and redoing the instrument cluster light tunnels. Makes a huge difference.
Geaux Tigers!
No big deal as long as you keep track of the scews. Also, make sure you snug everything down and if there's any trim tape padding missing replace it. If you don't do those two things you can come up with some wicked rattles.
on an unrelated note, I do not recommend world upholstery's molded carpet replacement set. I did a fair amount of research before buying. The carpet itself is ok (I got the domestic pile carpet, not the "import"), but the fit is only so-so. It may be that it will settle down to properly conform to the car, but even if it does, the pattern is not the best fit. still, a major improvement over the old carpet....
it may be that the cut and bound set is much better, but I bought the molded set because they said it wd be easier to install.
If you follow Clarks procedure, on step 4 it tells you to remove the control ***** from the climate control panel. DO NOT remove the round *****! It is not necessary and you will probably end up breaking one. Only remove the two slider ***** by pulling them off. Then remove the face panel trim and go from there.
I did this back in 2005 and my recollection is that the clark's directions were pretty complete. I would also suggest that you replace the clock light bulb while you have it apart. My clock bulb gave up right after I did this project and I've never had the energy to go back in to fix it.
It took me a full weekend, but I tend to go slowly and clean everything as I go. It was not hard, just time consuming and a bit nerve wracking. I've had no problems with creaks or rattles since.
1 Post
OT: are the "top" and "bottom" of the late dash connected, or different pieces?? my friends '86 has a dash with a black top, and tan bottom section. we were wondering if it was possible to swap just the bottom parts or not.
The late dashes are one piece. The top and bottom sections cannot be separated.
You will probably discover that the foam on the center vents is shot/deteriorated. Now is the time to correct this. Get 1/4'' upholstery foam and some spray glue that wouldn't attack the foam. I replaced mine by myself but it would have been best to have two people when placing the dash inplace. For some reason I kept trying to install it and was constantly holding it too high as I shoved it forward. There's a clamp in the center that its got to mate. I suggest you place a mark/tape to windshield something to aim at for the correct height before you remove the dash. Not as scary as it looks. I would also suggest u put removed screws into the new dash for each piece u remove. That way when you're ready to install all the pieces the screws are right there.
