Tire Size
Tire Size
can i fit 245/45-16s on the front of a 944S? I can get them onthe front of my turbo S with no problem but those fenders are rolled.
Depends on your alignment. I have maxed-out camber and the car is lowered with the m030 struts and I get a bit of rubbing on the inside of my tires against the brake line bracket and the fender liner. I don't come anywhere close to the outside of the fender well, though.
I run 225/50/16 race tires, which are really more 245 sized (r-comps love to lie about what size they are) and they fit okay.
They will probably fit but might occasionally rub. Don't know if it's worth it.
As far as I know the alignement is a street alignment and the car is not lowered. has adjustable Konis
i currently just have my 15" phone dials on right now so i cant tell you the exact size of my other tires, but i think they were 245/ 45/16 in the rear; anyways when i got some new rims They came with some pretty crappy tires, but the small time i used them on my 86 NA they did rub a bit and the fender put a couple small slices in them. They will fit, but i'd roll the fenders to be safe
That makes sense.. I always wondered what takes you so long and where you go between the Start and Finish line at the events. Now I know you are on a Humanitarian mission. Maybe you would go faster at the beach if you put the Sand tires on.
