Shift Boot Install? Pics, this doesn't make sense...
#31
![](http://home.comcast.net/~joejackson951/clips/sun02.jpg)
#32
Thinking outside da' bun...
bump
#33
The shift **** should go down far enough to completely cover the rubber bushing at the bottom. You are missing the wire form clip that then retains the shift **** by hooking under that bushing but that's not causing your issue.
Pull the shift **** completely off the shift linkage. There should be a rubber bushing on the top of the shift linkage arm similar to the one at the bottom. Look inside of your shift **** where the shift linkage inserts. If you cannot see metal at the top of the hole, you likely have an old rubber bushing stuck up inside of your shift ****. Use some needle nose pliers to remove it and your shift **** should seat properly.
If some of this doesn't make sense, I can snap some photos to help.
#34
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Don't know why you guys are having so much trouble installing shifters boot replace mine twice in 26 yrs I've owne my 944 each time it when like melted butter in the pan no problem LOL when installing I don't swear at it just just talk to it in low tone voice & be patient pics of the last one approx 8 years ago of course I retinted it since then.I think your rigth Joe the upper rubber bushing mith be the culprit if you have migth as well send them in.
#35
#36
Took boot off. Stuck a screwdriver up the shaft and didnt feel much. Its pretty tight up there. Put it back on and took the tried and true brute force approach (rubber mallet, several blows), and got it down far enough so the boot doesnt snap off in the gear throws. Problem solved.
#37
UDP, did you look inside of the ****? It should be just as open at the bottom of the hole as it as at the top. If your screw driver felt tight in the hole it's because something is stuck in there. Hopefully you didn't damage the bushing at the base of the shift lever with your mallet whacks.
#38
I didnt take the **** off because I didnt want to deal with re-fitting the leather. Works fine now.
