weird extra keyhole
what the hell is this, i have the extra keyhole and i have no idea what it is for, its next to my door lock key hole but its over the part where the door meets the metal. can anyone help me?
Former Vendor
Hi!
It's for OEM alarm. You should have another key for it.When it's horizontal ie aligned with your door lock,the alarm is off.When it's turned vertical,the alarm -and immobilizer- is on.
Look at the car's ID-tag in your trunk,there should read "533" in the Options Code.
Cheers,Pete
Cheers,Pete
$50 and an hour at a locksmith with land you either another key, or keyed to the ignition. I'd be willing to bet that there's a code somewhere on the tumbler too, so Porsche dealers could cut you a new one from tha code.
Or you could spend ~$100 and install a remote entry w/alarm and wire the factory alarm in with the kits alarm.
A few different ways to take advantage of the nice little extra you happen to have.
That's for the OEM start-disable system. You can check to see if it's still active by pulling off the inside panels and using a shorting clip on the switch terminals to see if your car will still start. Mine was removed at some point before I got it, so I installed a new radio-alarm system that includes shock and door-opening alarm, not just no-start.
