Sunroof problems. Any way I could just tie the damn thing down?
Old 10-11-2008 | 01:14 PM
KuHL 951's Avatar
KuHL 951
Hey Man
Originally Posted by Spidey944
Sounds like something to add to my to-do's. What kinda weight savings if you remove all the power stuff??
About 9 pounds with the early style SR motor and gearbox
Old 10-11-2008 | 09:02 PM
Po924S's Avatar
Po924S
So I went and checked the motor thing out. And the sunroof gears dont move up, or down. My motor is working fine, but it isn't spinning the drive shaft. My sunroof gears are basically brand new becuase the PO had installed new ones before he sold it to me. To check out the shaft, do I need to remove the motor, or remove the whole thing?
Old 10-11-2008 | 10:04 PM
DarylJ's Avatar
DarylJ
The clutch is probably too loose. Check Clarks Garage for the adjustment procedure.
Old 10-11-2008 | 11:00 PM
Po924S's Avatar
Po924S
I finally got it! Still have some problems though, and broke two things in the process of fixing. The drive wire was hardly in the motor thing, so I manualy turned it till it was all in the motor. Then I clicked the sunroof switch and the arms started to move. I got the left arm to grab tightly of the sunroof, and it pulled it down (kinda half *** grabing it though), but the right arm wont grab anything becuase the clip it's supposed to grab on is broken. It's on tightly enough so it wont lift up anymore, and thats all I really care, lol.
Old 10-12-2008 | 12:01 AM
Catfood's Avatar
Catfood
I was rolling on the highway and I hit triple digits and the sunroof was trying to fly away. Dont worry it wont go anywhere. Just looks cool. But I fixed that problem with RTV around my sunroof seals. If you decide to fix it RTV will come right off easy.
Old 10-12-2008 | 08:03 PM
billthe3's Avatar
billthe3
I've never had any issues with my sunroof popping up at high speeds, but that may be because the seal probably doesn't seal at all and enough air leaks out that I don't have any issues with the pressure differential.
Old 10-12-2008 | 08:26 PM
eniac's Avatar
eniac
That could be. Funny thing is I can get it about 10 mph higher before it pops up if I turn the air recycle on. The last time it popped open it hurt my ears so bad, they rang for 3 days after.
Old 10-12-2008 | 09:25 PM
KuHL 951's Avatar
KuHL 951
Hey Man
I have trouble following some of these SR popping up complaints. I've driven at 140 mph with my manual latches in the tilt-open position and the SR is pushed down not up. I won't drive above 125 with the windows down or cracked, it's a sure way to get that wupp-wupp sound as air tries to pop your hatch open. With the manual latches in the closed position it's tighter than a...on second thought I better not go there.
Old 10-12-2008 | 09:36 PM
JohnKoaWood's Avatar
JohnKoaWood
Don't know, maybe I could be wrong, but after rebuilding the drive system on my roof, I love it.. a nice afternoon on my back and the top works like a charm, I open it almost daily, and take it off when I get the chance...
Quick Reply: Sunroof problems. Any way I could just tie the damn thing down?
