FYI: Cheap, knock-offs on ebay - buyer beware
Says right in the brake ad....
Please note: This is not the OEM Porsche calipers by brembo, it is very high quality aftermarket calipers using best component and material.
Check our feedback and bid with confidence!
Just to be fair, I should add that I bought the camber plates too. I didn't have a problem. The seller was responsive when I had a question on installation. I'm surprised, though, that they wouldn't refund drift-a-944 when he protested.
I purchased the plates after reading a decent review from someone here. I have Bilstein escort cups, so that may explain the different experience (at least as to ride height).
Before you installed them, did the bearings turn by hand? Mine were frozen solid, and when installed on the car they popped like mad crazy. After removal they still didnt budge.
And also they didnt raise the car up at all? My car looked like it was ready to do some rock crawling after I installed them. My car does have Bilstein shocks and A-1 Racing coilovers which arent much different size wise from most other coilover kits out there. And they looked exactly the same when installed as in your picture. So, I dont know. I'm glad they worked out for you though.
