injector harness short to ground fries DME?
no it won't do anything. The injectors work by being grounded via the DME. When I had a bad injector problem I shorted to ground to get the circuit back to normal
Yes it can, one side of the injector gets 12VDC power and the other is connected to the DME driver transistor. If the short in the harness connects 12VDC directly to the DME driver wire, it can do a couple of things. One, like Brian stated it can blow the fuse or take out the DME relay. Two, the DME driver goes into thermal runaway and destroys itself thus making the DME a paperweight.
