Speed & Reference Sensors
#31
beab951
Hope I didnt upset you - hard to tell in text. I agree scope is the best method - just dont have one. Thanks for all the help.
My speed sensor is well and truly stuck in. Needs a 26mm spanner and socket bar with plenty of wellie to even turn it slightly. Mole wrenches and screwdrivers cannot lever it out - body just bends. I can see the bottom of the sensor under the bracket is turning when I turn the top, so the tin section is still well connected to the plastic section, and it doesnt look corroded. There appears to be an o-ring at the top which may be stopping my WD40 from getting down the side of the sensor. Perhaps someone used an oversized o-ring when last replacing the sensor.
I don't want to remove the whole bracket as this appears to be adjustable and I would'nt want to move it unless I really have to. I will probably remove the inlet manifold, etc to get better access.
I shall be really pissed off if its the ECU thats bad!!!
#32
Head of the speed sensor came off so I am going to have to remove the sensor bracket after all. I notice that it is adjustable. Has anyone got the manual details showing how to replace it correctly? (Porsche 944 Auto 1983)
PS Site seems to be incredibly slow today.
#35
PS will the Ref mark sensor automatically be OK if the speed sensor is set up OK? (I'm assuming that they are identical) - from the Haynes manual it looks like the ref pin on the flywheel is allen adjustable.
JD
JD
#36
Since the bracket changes the depth for both sensors, in theory you don't. It is best to check it with a piece of wood. Stick the wood shaft into the bracket and mark the depth, then compare it to your sensors depth.
![](http://boards.rennlist.com/upload/Al_bracket.jpg)
![](http://boards.rennlist.com/upload/ref_sensorstud.jpg)
The ref sensor pin is adjusted when it is installed.
