Distributor rotor screw
You should be able to unbolt the rotor assembly from the snout of the cam, one bolt holds it on, its keyed so it only goes one way. Just take the whole thing off the camshaft and work from there. Cmon guys, no hammers on a Porsche. Thats a yayhoo's way to solve a problem.
Id help you out man, but Ive got labs in 30 minutes and I won't be out till 5. There should be a hex bolt I think somewhere on the front of the cam, bolting into it from the side. If you pull that bolt loose, you should be able to get the whole rotor assembly thing to slide off the cam, so you can put it in a vice/lathe/drill press/mill or sometihng and very carefully get that stripped screw out. It happened to me because of a poor mechanic/previous owner stripped it in there. A huge bummer!!!
When I get back if nobody has pointed out the bolt ill go out and take a picture of it on my car.
Former Vendor
This happened to me a few years ago. I took a can of dust off (the compressed air you use to blow dust off your computer keyboard for instance), inverted the can and and froze the rotor with the propellant for about 30 seconds. A few light taps with a hammer ( and yes it's okay to use a hammer on a Porshe), it shattered and I was able to use vise grips to get the hex screw out.
(You'll have to check with the membership here however to see if vise grips can be used on a Porsche).
(You'll have to check with the membership here however to see if vise grips can be used on a Porsche).![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
