Airbag light reset - where?
I have a 1988 951, and the airbag warning light is on (in addition to the seatbelt and main warning light). I found the instructions for resetting it on clarke's garage, but I cannot find the white three-socket plastic connector that the instructions refer to. It says to locate it under the passenger side dashboard, but I've practically disassembled the entire dash and still don't see it.
Can someone please give me explicit instructions on where to find it, or even better a few pics? am I missing something obvious here?
Thanks for the help!
If no one can help, I can probably get pics tommorrow- we pulled mine, as well as that little orange box, etc. I am not the one who really did it- I just watched, otherwise, I could probably tell you a bit more. Can you see that orange box? That's the control for the airbags (I'm assumig you know this). Not sure if this will help you find the rest button though. I just know I wanted rid of the thing forever & finally have it gone. Of course, my car is not running, so I can't actually DRIVE it, but hey...
BTW- you said you are somewhat dissasembling the dash...? You get to all of this from underneath, so I don't think it would help you to dissasemble anything at all. Are you trying to KEEP the airbags & just want them reset?
Yes, I did see the orange box under the dash.
You are correct, I am just trying to reset the light, not remove the airbags. I didn't think that I was supposed to have had to disassemble the dash, but when I couldn't find the connector by just looking underneath I starting removing panels...
http://clarks-garage.com/pdf-manual/elect-12.pdf
There are instructions from clarks garage. Hopefully that helps.
Pics please!?!?!
