How much blow by is acceptable
Saikou Michi Catch Can Surprise
WOW!!! I'm in shock....have been driving the car around easy, short runs of 20 30 miles on low boost and have logged around 300 miles on my rebuild. Just kinda getting to the point where I feel everything is as it should be (still have some minor tuning issues) before REALLY having some fun with the car. Drove down to a local autoX event (Irvine, CA) to check it out. Looks like a S-load of fun, hoping next month the car will be ready. Heading home I took the long way through some canyon roads in the area for "fun". When I got home thought id see if there was any oil in the CC....whoa!! 6oz!!! Is this normal?
I had a Lindsey Breather tank on for a short time and had drilled out the top of the AOS as recommended by LR. More than likely my problem? Agree? or are there other possible issues.
Thanks as always for your help.
Couldn't tell you...Completely rebuilt motor. Just changed the oil last week after first 200 miles. Ski suggested the rings are most likely still seating in. Just didn't think there would be that much oil collecting on a fresh motor. I'll see how it goes over the next couple of weeks and see if the amount is less the next time. The one thing I though might be contributing is that I had drilled out the AOS when I was running a LR breather tank before the rebuild. The hole is almost twice the size.
Lazer Beam Shooter
I get more blowby that Rosie O'Donnell after Taco night. JK JK!
I think most of it comes from the turbo. It seems to not burn any oil unless I get on the boost.
