Top end rebuild... PICS and couple of Qs
So I started to tear down the top end of my '86 to deal with bent valves and what not. So far I got the intake off, the belts removed and I'm working my way towards the valve cover and the head itself.
Couple of questions :
1) To get the cam housing off, i just need to remove all the hex bits that are by the header and inside (going through the goofy wide bolts).. right?
2)I seem to have a missing vacuum line somewhere - I found it sitting on the block half melted. I've got two 90 degree bends near the firewall and 2 empty nipples (PICTURE 1)... I'm guessing they belong to the nipples but I have no idea where the long vacuum line (purple thing on PICTURE 2) is supposed to go.
3)Do I need to take off the inner timing belt cover plastic to get to the water pump? I don't see how I'm supposed to get it out with the plastic being there...
to remove the water pump yes you should pull the inner cover- which will require removing most the rollers, tensioners and lower pulley on the crank-which is very tight.
-yes remove the cambox lower bolts and the six? under the large 8mm alan caps and it'll come off.
- do a search for n/a vacuum lines- there are lots of diagrams floating around on here that are very handy. Ive printed most of them out and have them hanging on my garage wall. i pretty much rip all the vac. lines out and follow the diagrams each time to put stuff back correctly.
No that one is intact (the one that goes from the throttle body to a T and one end of that T goes to fuel rail and Ts to the FPRs). There was a another one that was sitting there exactly as I drew it.
