Accessory Position Ignition Queston
I have an 88' 924 and do not have the manual to research. I have an aftermarket stereo that remains on even when I pull the key out of the ignition. I have to actually turn the stereo off. I am wondering if the PO hooked it up to constant power accidentally or if that's how they are all hooked up.
Is the fist turn on the ignition (1 click) the accessory postition? The way it's currently hooked up just doesn't seem right. Any help would be great.
TIA!
TIA!
You're right - they wired it wrong. You should find a keyed power as well as a constant (for keeping the radio memory) back there. Sounds like the hooked both of the power leads of the radio up to the constant power lead.
The way my Blaupunkt MP74 is wired is that even without the key in I can hold the power button to turn it on.
Or, it will come on when I turn the key to the right. So it comes on with the car, and it will turn off with the car. But, it is also wired to the 12V constant so it can be turned on without the key.
I believe in my car the first clockwise click is the Acc. mode then "ON" is just beyond that.
EDIT: D'Oh:
"I have an 88' 924"
Yeah....I didn't read/remember that part. Sorry. Ignore this post.
I experienced something similar today, when I fired my new car stereo up for the first time. The previous owner took whatever stereo was there so I've had to figure these wires out using the current diagram and dumb luck.
After finding the only unattached red/white wire (radio wiring diagram suggest this wire would be the one that provides ignition-on voltage), I hooked everything up, and all works good--except the stereo can turn on even with the key off. I then tried using a red/blue wire in the same bundle, but the same thing happened. Both wires show 12V only when the key is on.
Nick
Nick
New information...I didn't realize the voltage shows up when the key is inserted. Remove the key? Stereo shuts off.
Still didn't prevent me from running the battery down while I marveled over this achievement, though.
Nick
Nick
Under the Radar
Ignition switch is different in an early car. It goes 0-1-2, where:
0 is the position where you can remove the key
1 is run
2 is start. No accessory position, though nearly everything works when you set the key to "run."
Only the radio works when the key is set to 0...you get voltage, as Nick said.
1 is run
Even newer information...the red/blue wire loses voltage when the key is removed from the ignition. The red/yellow wire, however, does not. Voltage is present even with the key removed.
After looking at the current diagram, I'm wondering if the "radio relay" is missing? Does anyone know what it looks like, and where it'd be, relative to the other radio wiring?
Thanks,
Nick
Thanks,
Nick
Thanks,
Nick
Thanks,
Nick
