who was selling stone guard sets cheap?
i found em for 50 on ebay with a buy it now of 60. they put them up once a week. dont bid against me this week please.
BTW Dan, do you have any smacked up front fenders? I want the bottom corner to learn bodywork on the S2 on. i know drop it off in cinci for a week and it will be better than new.
Also, what 944 connections do you have in cleveland?
Dan P and those guys live in near cleveland- im a few hundred miles from there- i have one red ds fender but thats it and i'd rather not cut it up. Dan.''
i'll check around for those rock guards.
Dan,
if it isnt smacked up i dont want the part. the rust is too small to replace the fender and may be too big to bondo. havent opened up the patient - or should i say can of worms yet.
I know that you are wanting to learn the proper way to this repair. But having done this myself on a couple of previous cars.... I would simply replace the whole fender. It's the rear quarters and rockers that I repaired, so cutting and welding was the only repair. It's a ton of work, and getting it smoothed out is probably the biggest part of the project.
How big of a hole are you looking at? Depending on the extent of cancer, it is possible to simply patch in some sheet metal, and fill the gaps with low heat. With a little technique, you can span ¼" gaps pretty easily with a MIG welder. It won't look too pretty on the inside, but only bugs will ever see that.
Something else that can help you span gaps when welding would be a copper backing spoon. The copper conducts electricity, but the steel wire that you are welding with doesn't really stick to it, allowing you to remove the spoon, leaving the weld behind.
Are you referring to the clear pieces that mold onto the certain parts of fenders and what not? if so i believe i have a set that came with my car that i was going to sell or put on and never did, if so id sell them for that..just let me know.
See the cracked piece of black plastic just over the rust. the car has six of them. Those be the stone guards.
Judging by how high the cancer has spread, you will probably be better off with either a whole fender, or at least what you were looking for to begin with.
