Looking for another 944
Old 06-22-2008, 10:47 AM
roman944
roman944's Avatar
because early dash's are HOT and new ones are NOT
Old 06-22-2008, 03:22 PM
Stien
Stien's Avatar
I'd love to get my car sold to a 'lister and not some punkass fool. C'mon you know you love the late dash too...
I'll end my ebay auction...
Old 06-22-2008, 05:12 PM
WizPorsche944
WizPorsche944's Avatar
Whats all wrong with it ?
Old 06-22-2008, 05:29 PM
Stien
Stien's Avatar
Here is the ad if you want to take a look at it:
http://cgi.ebay.com/ebaymotors/ws/eB...m=270248578400
THe problems(taken pretty much word for word from the ad): Ebrake cable is not connected to the handle (I was in the middle of replacing them) and the handle is disconnected from its mounting bracket. The clear coat is peeling off on the hood, the roof, sunroof, and a little on the rear fenders. Whoever repainted the car didn't take the stone guards off before they painted either. A/C needs a charge, battery is toast, I jumped it today and it started right up and idled great. Has a brake booster vaccuum problem as the pedal does not return up fully after a brake, probably just an old cracked vaccuum line. It is not a master cylinder problem or a leak because it doesn't go through fluid. The front valence is a little banged up and I'm including a good condition white one with the car. I took the power steering belt off because of a leak in one of the lines, the steering is a little heavy without it but definately manageable. The horn doesn't work, which I'm told can be as easy as a blown relay.
As for the good(also taken from the ad):
just did pads, rotors, balljoints, 2 new calipers, fuel pump, fuel filter, fuel pressure regulator & damper, timing belt, water pump, balance belt, e-brake cables and shoes. Fuchs, LSD, front and rear swaybar option(404).
Old 06-22-2008, 05:34 PM
WizPorsche944
I wish you were closer b/c its woild cost me a fortune to ship it. Want a 914 ?
Old 06-23-2008, 12:07 AM
WizPorsche944
Done deal Guys I just bought Stiens car.
Quick Reply: Looking for another 944
