rear sway bushings part #?
While attempting to adjust the camber on my car I noticed the state of the bushings on the driver side rear sway bar were very bad, the bottom one had slipped out completely, and the top one was halfway out. I'm looking in PET, and I can't find the actual bushings, the only part I see is the one they go into, 477 511 051 A. Are the bushings a seperate part #, or are they sold as part of the above one?
The rear sway bar centre bushings are a single unit with a split - they *should* not be in two pieces.
Finding the actual part # will depend on what size your bar is - 14, 16, 18, 19, 20 ? What year/model, and any sport or upgrade options?
FWIW, since the bars are an easy and popular upgrade, it's prudent to actually check the diameter of the bar to be sure you are ordering the right replacement parts.
Good Luck!
Good Luck!
