Any reason I shouldn't dispose of this OLD but unopened motor oil?
Cleaned out the in-laws' basement yesterday and found four quarts of Havoline Supreme 10W40, plus 2 quarts of Havoline Dextron II auto trans fluid. The stuff must be at least 20 years old (it's in quart cans!)
They're going to the dump unless someone thinks there's a reason to use them. From what I've read, the dino stock 10W40 is junk due to the modifiers used to create that range.
Ha Ha ! So true! I'm not sure 20 y/o product will get you much $$, but it all depends on how rare and desireable the item is. Generally, the more colorful ones have a higher value. I have Texaco stuff so old, that it's pre bar-code.
Dump it into a diesel's fuel tank. It's free fuel. Yes, it will even eat the ATF.
I have run a diesel motor on straight motor oil and it does work.
pic please ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I would love to have few american oil cans in my garage as a decoration..
I might be able to get $10-15 on ebay for the oil, but it's probably not worth the hassle.
the hassle of making some collector happy?? What if a ****-ring used by Abe Lincoln is what you had been searching for for years was just sitting around in a box somewhere?? OK bad analogy, but still!
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Sorry for hijacking, but Arash, have you given any thought to converting your 300TD to waste veggie oil? My brother is doing it to his 240D this summer, and i am to my Audi 5000TD/
My diesel is from 1982 before ULSD and before emissions systems were implemented on diesels (well it has an EGR valve but not a smart one so I bypassed it). Any diesel can combust oil, but on your new fancy GL320 it will probably make the onboard mainframe unhappy. +1 sell the cans as collector's items. Beware that shipping oil might be a problem with some companies.
