Need Help Now! - Car at shop, need wheel hub! Where/Cost??
Apparently my horrible noise and things = the Wheel Hub. (rear)
It's the 'thing that goes through the center of the bearing, studs are attached to it, it holds the wheel on', is what I remember from the mechanic over the phone.
His parts guy doesn't have it, another parts person has it for ~$550, + shipping.
I need to know what the part # is, or what it's normally called. Not finding it on Pelicanparts. The rears should be the same side to side.
The wheel bearing froze apparently and erroded the hub. =(
What are my options here? Help!
(I have an 85.5 NA 5spd)
North East
Phila PA/Northern NJ
Found a local breaker ('they pull it') that has one. How can I tell if an 85 if 85/1 or 85/2? I have the VIN
WP0AA0941FN473974
WP0AA0941FN473974
Crap!
Do the 85/1 and the 85/2 have the same rear wheel hubs?
Theirs is 85/1!! Are they the same?
I'm thinking no... but the catalog names don't help. The first = 82-85, the second = 85-88... ???
477 501 065 - 85/1 (in E_944_85_KATALOG.pdf)
in E_944_88_KATALOG.pf
951 331 067 00 -86
A 944 331 067 01 87-
944 331 067 01 87-
951 331 067 00 -86
944 331 067 01 87-
On the Radar
I thought you needed a front hub.
Sounds like you need new rear bearings and a stub axle.
I think they are the same. Maybe someone else knows better.
You will need an early offset shaft and hub.
The part # are:
Rear wheel shaft #95133223501
Hub #95133106700
You will also need ten wheel bolts #90434167100, two circlips #N0123501 & two bearings #99905302001
All available used from dc automotive
The part # are:
Hub #95133106700
The part # are:
Hub #95133106700
The part # are:
Hub #95133106700
The 'remarks' in the 944(2) catalog say -86 and have the 951 part #... crap. I guess I should fleabay it.
You could also try pelicanparts or these guys. Not to mention the guaranteed-awesome rennbay.
dcauto are quite competitive on the used hub and shaft, Ian at 944online also parts these cars so he might be able to give you a better deal. He can also supply the wheel bearings, circlip + the nut at the end of the shaft. These you need new, so either 944online or pelican or paragon or sunset or any of the other vendors out there.
I don't think Rennbay carries any of these parts but I could be wrong
Mike
+1 though they don't all carry these parts used.
Mike
Mike
