My headlights drain my tank and overheat my car...PLUS NA sighting
Rainman
Lol.
So I went on a roadtrip to Riverside today and was blazing along in the fast lane around 80MPH. Whenever I saw someone going a bit slower than me I would flip my headlight switch to the first position (just corners/markers on) and turn on my foglights to tell them to speed up or move over.
I noticed I was getting low on gas right after I passed someone, so I turned off the light switch and the gas needle jumped a bit. At the same time I saw the car was running hot, so I turned on the fans and it helped a little, but when I turned the lightswitch off the needle dropped to center.
I just replaced my headlight switch a few days ago.
I also noticed that when my radio is on with the car off, the radio shuts off completely when I crank the engine. Before I changed the starter it wouldn't do this.
What the hell is going on with my wires?
oh, and I saw a red NA heading south on I-215 about 12:30 near the Ramona Expressway exit..anyone here?
1 Post
and i too changed my starter within the last couple of months, dont know what it did before that though.
You don't need to click your headlight switch to flash your fog lights. Pulling the indicator stalk while the headlights are down will flash the fogs (instead of high beams).
And it sounds like you have a bad ground somewhere.
I noticed the same thing on my car when I headed out to do my first DE 2 months ago....having just had the starter changed.
It's definately a ground issue as the car performed flawlessly otherwise.....
Rainman
anyone have that grounds diagram handy?
Rainman
My alternator is about 2 years old, it was a new unit, I believe Bosch.
Anyway the weird thing about the radio is that it never did that before. The stock starter would crank over without affecting my electronics except the headlights. The reason I replaced it was because its bearings were shot and noisy from age and alot of use.
I'll go check my grounds later while I beat in part of my floorpan because my big new tires are rubbing a bit...lol
Normal for the radio to shut off while cranking starter. if it didn' shut off when cvranking before and you only changed the starter then something else is wrong. Changing the starter switch could have an effect on that though.
[QUOTE=V2Rocket_aka944;5446743]i would just turn the lights on outright and leave them on while i approached someone in front of me.[QUOTE]
kind of rude don't you think?
Rainman
maybe.
i only left the foglights on when i was approaching from a distance, so they would be more likely to see the brown missile barreling down on them. if someone jumped in front of me and was going alot slower than me i would flash at them.
