931 nose panel removal
Old 05-16-2008 | 06:46 PM
thf944's Avatar
thf944
Default 931 nose panel removal
So I found a 924 turbo that I'd like to remove the nose panel from. What's the best way to do it? It appears to be welded on. Is there an easy way to get it off?
Old 05-16-2008 | 07:03 PM
thf944's Avatar
thf944
there's also a hood with the scoop available if someone wants it i could snag it.
Old 05-17-2008 | 12:50 AM
Will Feather's Avatar
Will Feather
They header panel is just the same on the early 944. You have to drill through the tack welds to remove it.
Old 05-17-2008 | 02:43 AM
Calmchaos's Avatar
Calmchaos
The next step after the nose panel removal is sending it to me free of charge!
Old 05-17-2008 | 09:41 AM
931GT's Avatar
931GT
yes this is why 931s exist... so people can rice up their 944s. I think you'd be better off doing a motor swap. At least then you'd gain some performance.
Old 05-17-2008 | 12:01 PM
thf944's Avatar
thf944
my plan is to create a 924 carrera gts replica...
Quick Reply: 931 nose panel removal
